Its probably your power steering pump leaking because its above your A/C compressor and its dripping on to the compressor...Pin point the leak exactly and check the level in the resevior.
i have had to top off the PS fluid recently, after 2 months of ownership i topped it off with a little bit of fluid, i know that needs to be resealed but those 2 hoses if you push up on them they show sign of fluid loss...right at the metal meeting the rubber. my AC performance has not changed at all tho since i got the car at least as far as i know it hasnt.
something at the belt line, or just below it (as car is moving) it flings some fluid around, since a bulk of the grease i just wiped dwon the other night was around the PS pump and the AC compressor i figure its the ps pump.
unless its falling right on top of that metal AC line, and dripping down, as the top of that hose is also pretty caked with grease and giving me the image of fluid loss, as AC R134a is not a liquid its a gas right? i had a bad evap core once on another car and smelled buring AC gass on the exhaust from when the evap core would fart and cause gas to escape and it smelled bad, and i dont have that smell at all.
