95 S280, 95 C280, 94 C280, 95 E320 conv & wagon, 94 E420, 93 300D, 88 300SEL, 85 300TD, 83 500SEL
The cover is torn on mine and before going to the junkyard I need to know what other models would have a wheel that fits? Any chance I would hit the jackpot and find a wooden type for the $14 they get for wheels? I see C-class 94-95 looks the same. Any others?
Mercedes 500E & CLK32K
That wheel was available from 1992-1999. For your application, you want a wheel from a 92-97 model. Starting in 1998, the airbag mounting assembly changed, so you would not be able to use your airbag on a 98-99 wheel. So you need to pay close attention to what year the wheel comes from.
You can get this wheel from just about every chassis.
Furthermore, if you get a wheel from a 94-97, it is a direct bolt on. If you get a wheel from a 92-93, you would need to remove the horn contact ring and install the plastic filler piece (from your original wheel)
