c320 problem list...
Hi all.<br>
<br>
Sorry to hear about your C-series problems.<br>
Here are mine. 2001 C320 16k miles.<br>
<br>
1. Brake squeal- dealer said it was the wheel cleaner that people use.<br>
2. Front struts squeaks, then the rear after a couple of months. It happens when car is driven for several miles and going over speed bumps and steep driveway. It happens intermittently. Been to shop 2 times, can't replicate. I was told to comeback when I experience it again.<br>
3. When stopped at the light specially when the car is just started, it sounds like the car sputters for a couple of seconds and then the car is fine all day. No faulty codes found. Could be the ABS, since I could feel the brake pedal pulsate a bit when that happens.<br>
4. Right front directional, the bulb socket is slightly scorced, had to sand it for better contact. Made of aluminum?<br>
5. Humming noise when driving on asphalt, shop said it was the tires cupping, all four. I rotate the tires every 7.5k miles- dealer said take it up with tire company.<br>
<br>
I had 3 SUBARU's with a total of 160k miles combined and never went to the dealer for any problem. Just regular maintenance. I also have a 1987 MB 190e-16 valve, 90k miles no problems. I think these new generation of Benzes are not well made. I am getting so frustrated.<br>
<br>
I hope this helps.<br>
<br>
Orlie<br>
<br>
<br>
<br>
