mercedes benz 230e 1991 w124 2.3ltr auto 4 speed
its got a whole in it and i really need to fix it badly as i need my car. its a 1991 merc 230e 2.3ltre, this is located on passengers side of car, (this is in a right hand drive merc) it is under the air filter box and the pipes on near the front of the engine on the left side of block, it looks like a bolt, it fits a 22mm socket to undo it, can u please help me figure this out please so i can get a new one vlcsnap-2012-08-17-21h36m09s34.jpg
the red stuff is gasket goo to stop it from leaking but it didnt work so took it off the bolt
1994 E320, 1990 300CE Coupe, 1971 280S
That is a threaded cooling jacket plug. Cheap part easy to change. You just need that and the o-ring that goes behind it. While your at it you may as well change your coolant cause you'll lose most of it while doing the job. Good luck.
Sid
Master Certified Mercedes-Benz Technician
Gasoline/Diesel/Hybrid Certified
AIRCON Certified
1994 E320
1990 300CE
WTB 1972 280SE
Sid
AIRCON Certified
1994 E320
1990 300CE
WTB 1972 280SE
thanks so much man. finally some1 who knows sumdin.
