1 - 14 of 14 Posts
1997 SL500
I would like to add heated seats so I want the factory look with the switches in there, so I want to order a new one like that. I can't seem to find out what part number it is though. Thanks!
If I see your pix correctly you have burled walnut wood, so the part number is 1296806636. You have to specify the slots on the console, since you want one with heated seat buttons, the layout is ES-2=5470.
1997 SL500
Perfect, thanks!!!
2000 Obsidian Black Metallic Mercedes SL 320 V6
Catterman if memory serves me in the back side of the console there should be already some pre-drawn holes. Maybe GUSMB could give you more accurate infos.
Cheers.
1997 SL500
Cheers.
So you mean I can just take the dremel and cut holes in my current console? Is there a spot already there underneith my console where the factory switches can attach too?
Thanks!
Since you are ready to replace it with a new console, might as well remove the current one and take a look at its back side first. Hopefully all you have to do is to cut hole in the surface and save some $$$.
300SL (103)
I percieve a problem with cutting your own holes. THe switches are held in place as they click into a groove cut in the thickness of the pressed wood console pannel that runs all around the inside thickness of the hole. This is going to be quite difficult to cut. check out the other switch holes to see what i mean.
1997 SL500
Good point... My current console is a little cracked anyway, so a new one wouldn't hurt anything for me - other then my checking account... :D
Well Catterman since your console is cracked and you are after a new one I'd suggest you to have a look on Ebay in case there is one so you might also save some money and if you are lucky enough you might find one that has all the holes you need and maybe also a few spare ones.
Cheers.
Outstanding Contributor
'03 SL500, '03 SL55, '97 SL320, (2) '91 300SL, (2) '91 500SL, '00 S500 -- all for sale
I believe this is not the case. The switches are held in place by a plastic retainer which is stapled to the underside of the console. In my mind the only difficulty with the OP's project is to cut a neat-looking opening for each switch into the console
1997 SL500
Discussion Starter #11
Winter is pretty much over now, so I will keep searching ebay for a good price on one. Even if I can cut my own holes and have them work I would like a "newer" looking one anyway. But with a wifey and kiddos at home I don't want to spend an arm and a leg on these things anyway.
Catterman I found a few consoles at reasonable prices on Ebay in case you want consider them :).
LINK1
SILVER ARROW CONSOLE !!!!
LINK 3
LINK 4
SL EDITION CONSOLE !!!!
I know that not all of them will be suitable for your car but since I am not sure from your picture the color of your console and since I found some special ones I decided to post all the consoles I could find.
If I went to much off topic please feel free to scold me (not too much tho please lol).
Cheers.
1997 SL500
Discussion Starter #13
Hey Thanks! Your Link 1 is a match for my car! I will see if the wifey will let me get one already! :D
Catterman if you tell your wife what it costs at the dealer and what it costs bought on Ebay I bet my ... life that she will say go. Especially if you sweet talk her into it;).
Good luck mate :).
Cheers.
1 - 14 of 14 Posts
