1994 Mercedes E320 wagons (2)
On my 1994 Mercedes E320 w124 wagon, I had been researching like crazy trying to find this particular part and the specific type of rubber mounts that goes on both ends of the hooks (including the catalytic converter hook). I need replacement parts that is near by the passenger side firewall near the screen cover area. This particular part is also bolted on the screen cover using the small middle hole on the bottom of the part (see the photo). It was bolted on by the firewall. I removed it because it was twisted due to flexi-disc failure and caused all kind of chain reactions to the damaged parts that I am now replacing. I have been trying to find this part and its number that goes on the screen cover and has the end hook with the rubber mounts connected to the catalytic converter hook. In addition, the rubber mounts came all kinds of different types and sizes and I am not sure which one is appropriate for the issue at hand. I enclosed some pictures of the part that I removed. Notice the picture of the bracket (?)that is on the firewall with a bolt underneath it. Is that part welded on the firewall (see number 5 and the photo with the bolt under it
) or can be removed? Does that particular piece need to be replace or I can twisted to its normal shape without breaking it? The bolt goes on the part I removed as shown in the pictures. Hopefully, someone can identify this part and the number as well.
The closest diagram I came up with does not quite fit with the pictures I enclosed in this post. If you look at the diagram of the screen, it seems #5 is the closest one that is on the firewall or body of the wagon along with # 11 that looks like going to the screen hookup. It is pretty close to the setup here but I am not sure if that is the correct part in the diagram in comparison to the picture. I do not see any hooks on the both ends which the rubber mounts (also not listed in the diagrams) goes in. Or maybe the drawing is off and wrong kind of diagram.
I hope I gave enough information to find out what is the part name and number. Does anyone out there knows about this? Any additional parts that are missing as well that I need besides the ones I already have? Thank you all for reading this post.
Discussion Starter #2
I found the part on ebay and bought it!!
After hours and hours of trying to get this particular part, I found it on ebay. The part name is called Mercedes W124 E320 Exhaust Hanger Bracket. I found the name of the bracket was odd, although the part is consider to be part of the complete exhaust assembly. In addition, there is no part number shown, either. See the pictures. Thanks to all for reading.
I was abled to get in touch with the seller of the item that I bought from. I asked about the exact part name and exact part number. The seller does not know.
I really wanted to know exactly the part name and part number for clarification and for future references, just in case.
Sometimes, a part has its part number etching for identication. In this case, it does not.
I saw too many different parts names and different part numbers means the same thing and not the exact part as described in the picture on this post. Sometimes, the part appears to be a u shape hook, others a flat bar. Often times, there is no picture or image of the part and when it does, it not the same part I am looking for. Does anyone out there knows the exact part name and part number of the item as shown in the picture in this post?
1995 E320 sedan, 1991 Porsche 964, 2004 Porsche 986
Part #124-610-23-25, in 61/15 (Substructure, Front Floor) of EPC.
2609114
2609115
