What have you done to your R107, TODAY ...
131565 Views 2108 Replies 195 Participants Last post by  Jeff Weiss
Be interesting to know whats being done to all the R107s on here.
Lets post a comment here when you do something each day so we will know what you are up to.
TODAY, I washed, detailed, and vacuum the interior on both Angel (380SL) and Sunshine (560SL) this morning.
Also installed Paracord to use as an emergency pull cord to open the Soft Top cover if it gets stuck.
(Uploaded pictures - all inside garage as it started raining right after I finished)
2021 - 2040 of 2109 Posts
Completed Number 1 and 4 of my winter to do list.
Number 1 was replace the upper control arms. You can see how that's done here:
Next up is fix leaks and powder coat the VC and intake manifold. That will put the car down for some time but I would like to get it done early as I no longer have a heated garage.
1976 450SL (Pearl)
Swapped out Pearl's leaking radiator with the one from the parts car. Also, moved her electric fan to her shroud from being attached directly to the radiator. It now draws air across the entire surface instead of a 16 inch circle.
1974 450slc 1972 280se 4.5
I drove mine! Sorting out the last of the squeaks and rattles. I am deaf in one ear so I have to have a reluctant assistant for location. rear swaybar bushings look good but noisy.
Engine getting smoother as I drive it but still need to do a plug check to see if there is a single or a suspicious pair that look different. OH and I fixed a wear problem in the driver door handle (not unlocking with key) by spacing out the little finger with beer can shims.
1976 450SL (Pearl)
At idle, pull wires (one at a time) to find which cylinder is not working. when you find the dead cylinder, swap plug wires (both ends, plug and dist.) with a working one. If the miss moves, it's a bad wire. If it doesn't, it's a bad plug or a bad injector. Pearl's had both situations.
1973 450SL
Installed new right side window seals. From K&K. Now to do left hand door...
Drove our beautiful back roads into town on a stunning fall Pacific Northwest day.
This car really "pops" with the whitewall tires. Lots of waves and thumbs ups.
Reactions: nobby
This is probably OK for older cars without electronic ignition. But do not do this on the 560SL. You might get away with it with one cylinder disconnected at a time, but if you pull the distributer wire it will fry the EZL $$$ and NLA.
1976 450SL (Pearl)
I meant the post for chiroracer and his ‘74. I still have problems with getting my posts to go where I want them to. Thanks for the info on newer ignition systems.
1979 450SL UK spec
Hi, I'm looking for a replacement NSS connector. Can you post the part #? Thanks, Rob
This is it for the 450, they are NLA, I got mine from someone on Facebook who bought a couple from a supplier in the middle east, you see the guy advertising new old stock on the "107 Appreciation society", on FB every now and again.
Rectangle Font Parallel Screenshot Operating system
Material property Font Rectangle Transparency Electric blue
92 300E 4MATIC(DD), 93 500SEL(Pa), 04 ML500(Ma), 86,88 190E(sold),'76 Sahara Yellow W123 200 (RIP)
Motor vehicle Chair Comfort Armrest Plant
Car Vehicle Motor vehicle Automotive design Car seat cover
Art Tints and shades Creative arts Pattern Font
Furniture Chair Window Automotive design Comfort
Collecting parts to retrim the interior of a 500SL Premerger AMG tribute. The seats will have Karo centers, black leather outter trim… going to redo the kinderseat and door cards as well. Thank you to @ivanismyname for selling me the Steering wheel, it will be retrimmed as well
