181 - 200 of 248 Posts
Mercedes-Benz 190E 2.6, 300E, Volkswagen Jetta 1.4T
I just did the ones on my 85 300D.
I am sure Kent's tool helps, but it is a bit expensive for a one-shot deal. On PP, someone suggested using a cherry pit punch! Something like this:
After trying the one in the tunnel, I decided to remove the lever on the side of the tranny as well as the shifter itself and do them on the bench (Used vice) Went in easily without lube or heat. Many suggested boiling in hot water, especially if doing the shifter bushing up in the tunnel. Silicone spray would no doubt help.
Kent's tool is a bit expensive for a one-shot deal, but I've used it on 4 cars now and have also let Fonzi borrow it. The one up in the tunnel is easy-peasy, it's the other one that isn't fun. The brass clip tool that comes with it is even better though as I've used it on throttle linkage clips, and it looks like it would work on a lot of the rod clips in the R107 soft tops.
1981 380SL
Today I limped, more so revved and lunged, into port. Took the car on it's longest 45min drive. On the way back about a mile away from my work it started to rev at a red light. A little closer it started to lunge and loose power even if I stepped on the gas. I pulled over once and it cut out. After a few minutes I started it up and it was fine for a little while. I got it into the lot and that's when I heard an extremely loud whine from the back. It is the fuel pump making the noise. When I first got it last year it revved at a stop bringing it home. I ordered a new pump so back under to the fuel pack I go.
1984 380SL
Finished installing the fuel/air distributer and getting all the fuel lines reconnected. Hopefully, I'll be able to do a fuel pressure check today and make sure everything is looking good.
2601928
1976 450SL
A while since anyone's posted to this thread...I've also been finishing up my motor. This is a '76, but I'm not going for originality. I've removed the cats and EGR, and replaced the manifolds with those from a 73. Still a few more bits and pieces to go before I can start it up again (waiting on a couple of parts, and haven't closed up the A/C system yet), but thought I would share...
2608118
And here's the 'before'
2608119
1974 450SL (always needs something!) new djet engine 1991; 1961 Besasie X-3 (being restored)
I looked at it.....
1986 560SL; 2012 E350
That's amazing! what did that cost and how long?
1985 380sl
Replaced my heater cover and gasket. The small flap on the passenger side was broken and waiting to fall off. Naturally while I was in there I vacuumed the dust that had accumulated over the years plus I shined everything up. Apparently I had time to kill, as I also polished up the tarnished screws and washers, which are now nice and shiny silver. This project had absolutely no affect on the performance of anything, but now when I pop the hood I can admire how lovely it looks.
2608277
2608278
2608279
2608280
1976 450SL
Thanks!
So far - just over 4 years (though work took me out of state for about 18 months, so really about 2 1/2 years. Prefer not to share the cost, but more than I'd like. I could have bought a good R107 for the money - but that wasn't the point; I was looking for a challenge!!
That said, I've done most of the work myself (except for the paint), and I've spent a LOT of time searching for 'bargains' on Ebay/Craig's List. As I've mentioned a few times, it's definitely not concours, especially in terms of originality. I'm building it for my wife, and she made it clear she wanted it to be a 'driver' and not a garage queen. She's already planning weekend trips!
It's not finished yet though. Apart from the obvious, the interior is restored (but in the basement); front end needs alignment and the grill/bumper/air dam installed. Plus a million small jobs. Hope to have it on the road before next summer.
Also - the motor is the original. I do have a low mileage 'spare' motor, but this one seems to start and run well (despite 250,000 miles), with only a little light smoke so I've decided to put it on the road and see what it's like before replacing it.
I finished up the engine bay tonight, and took the fender protectors off, so here's another photo, showing the big picture!
2608281
1988 560SL, 1969 280SL(113)
Thanks!
Looks great, and excellent quality pic!
1976 450SL
Thanks! I've also been following your 15" bundt thread. I've been considering getting a set of those for my 450SL. If you do manage to fit them on the car, I'm definitely interested in seeing some photos. If they don't fit, and your plans re the 113 change, I might even be interested in them (I'm also planning on Michelin tires as well)
-Steve
-Steve
Trying to fit them is a December project when I am back in USA. I will update here in due course.
1984 380SL
Drove it since it was sunshine on Friday and about 14 degrees C. It ran nicely and no tendency to stall when accelerating from a full stop. Seems the car is fixing itself once i started to use pure gasoline without the lead additives that i used before.
1984 300D, 1985 380 SL, 2009 E350
Replaced my rear shocks and tightened steering box (half turn left) - both changing my '85 380sl. I solved my hesitation issue at lights (similar to Ed9^) by Seafoam and driving the car daily with some Italian revs for a week. These cars don't like sitting which happened when it was no longer a daily driver for my son who left home almost 2 years ago.
1973 450SL and 2004 SL500
Approaching winter in Minnesota so today I put up the top, took my ‘73 450SL for one last drive for the season, fueled and cleaned her up, and parked her in her new home for the winter. I think that this CarCapsule should do a great job of keeping the car clean, protected, and also mouse-free this winter.
Sent from my iPad using Tapatalk
1981 380SL, 2012 GLK 350, 2008 Corvette, 2002 Nissan Xterra, 1965 Dodge Dart Wagon
I fixed a vacuum leak in the door lock mechanism.
Discussion Starter #200
I'm gonna drive mine this Winter.
Sunny South :)
Like Summer, there are days when the weather is nice and there are days when the car stays inside.
