Engine vibrates at idle and in gear. Vibration goes away in P or N. Trans mount was not enough, engine mounts are next.
Engine vibrates at idle and in gear. Vibration goes away in P or N. Trans mount was not enough, engine mounts are next.I never had any symptoms on three of my W210s when the motor mounts collapsed. Check the clearance on your bottom radiator hose and chassis.
That's a known issue.sadly that didn't solve the brake light that is out
Thanks! Looks like a new socket is pretty cheap so I ordered one of those along with some engine mounts.That's a known issue.
Permanent fix for tail light bulb socket burning...
So my car developed the famous burned out tail light socket. Here's an easy and permanent fix: Remove tail light from car. The pitting wasn't that bad, but it was definitely noticeable with my fingers. Ah, there it is. If you have access to a rotary sander or a sanding attachment to...www.benzworld.org
Check you cabin filter behind the glove box. Dirty wiper trough means lots of debris on the filters.Thanks! Looks like a new socket is pretty cheap so I ordered one of those along with some engine mounts.
Replaced the hood struts today so the hood will actually stay up on its own. Also cleaned a shocking number of leaves out of the engine bay.
Lately my E430 has been sitting in my driveway under a tree. And every morning my ritual is to take out the shop vac and vacuum out all the leaves in crevices and then open the hood and vacuum out all around a heater intakeThanks! Looks like a new socket is pretty cheap so I ordered one of those along with some engine mounts.
Lol......I do the same thing. My neighbors must think I'm a little bit wacky. I do the trunk lid seals also.Lately my E430 has been sitting in my driveway under a tree. And every morning my ritual is to take out the shop vac and vacuum out all the leaves in crevices and then open the hood and vacuum out all around a heater intake
if you don't do that regularly that junk will accumulate down by the blower motor
and it will clog up the drain tubes on each end of the firewall and then you can start to get rust issues
Which wrench did you order? I ordered this one today.Thanks! Looks like a new socket is pretty cheap so I ordered one of those along with some engine mounts...
It's a cover #380 and its tether #390. Part number will depend on model year and styling package.Finally took the project w210 for its first test drive after installing a whole new cooling system (radiator, fan, water pump, etc) and now I can finally move on to the much needed typical maintenance stuff. Planning to start with the power steering fluid flush/replace today. But I was wondering if anyone knew what this part is called or a part number by any chance (unrelated to power steering)
IMG_1920.HEIC
drive.google.com
If you don't do that and decide to change the blower motor it's amazing the crap that's in there and affecting the airflowLol......I do the same thing. My neighbors must think I'm a little bit wacky. I do the trunk lid seals also.
