1 - 14 of 14 Posts
1982 240D M/T White
I was wondering what 4" speakers fit under the grill in the dash ? I do not want to mount a seperate tweeter on the dash or window pillar.
I believe in an earlier thread Boston Acoustics FX-4 was mentioned. MB Quart Discus 4" coaxials should work as well, but they are "low end" for the brnad.
Will 4" x 6" "plate" speakers fit ?
The issue is the tweeter sticking up too far and hitting the grill for many/most 4" coaxial speakers.
Alan
BTW, just installed a Nakimichi TD-400 radio/cassette NIB (New in Box). Top end unit from the mid-1980s :) Another "Time Warp" item !
If I remember right, I used Pioneer TS-G1340R 5-1/4" 2-way speakers I bought at Best Buy. They fit with no modifications, just had to change the wiring connector. There is no way a 4x6 will fit in there.
2008 PT, 1998 neon--1965 VW 1200
i go with pioneer as well--
i got mine at wal mart for 40 bux and change, this was before i knew the spot was weird(or not "normal") and after i put them in in like 30 minutes, my radio sounded well--
pathetic.
ohh the joys of a clanky diesel with tiny little speakers in the front and nothing but an echo behind. atleast they put in air conditioning! naa, they sound ok, my car just has no rear speakers(or fader, or tape, or stereo)
it does have an ipod, however. so i have arguably the best sattelite speakers for my ipod available! too bad they weigh 3400 pounds, huh? oh well-- theyre mobile!
1984 300CD, 1983 240TD Euro
AlanfromBigEasy - 5/3/2005 3:37 AM
I went with "Sony XS-W4021 4" 120 Watts 2-Way Speakers" They were an easy install and also fit under the grills. I think they sound excellent.
EDIT: $29.95 + shipping @ http://www.etronics.com
Details:
» polypropylene woofer
» PEI balanced dome tweeter
» frequency response 45-22,000 Hz
» power range 2-20 watts RMS
» peak power handling 120 watts
» sensitivity 90 dB
» depth 1-11/16"
Just thought I'd add... If you need OEM Used Excellent Condition...
MERCEDES-BENZ 123 ORIGINAL FRONT DASH STEREO SPEAKERS
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=7980244295
A
Guest
I used Pioneer 1040R 3.5" speakers up front and
they sound O.K. to me.
I used some Polk MoMo 5.5" in the back with a little
trim to the hat rack cardboard.
I'd like to know what you think of the TD-400, I looked at those because I liked the non flashey
look, but to much $$$ for me.
Alfa - 6/15/2005 1:48 PM
What's the "TD-400"?
[8D]
83 300D Turbo
I just replaced the speakers in my 83 300D. I used 5 1/4 in the rear and used the new grills that came with the speakers, looks much nicer. I used Pioneer 4" in the front. Now I trimed the metal on the speakers so they would fit in, and I could only mount them with 2 screws, but they are secure, don't rattle, and the factory covers fit back on real nice.
W123 560E
Check my reply to the "cutting speaker holes" thread so you can see my set-up because I think I have got good sound out of my benz, it's quite balanced too and probably the easiest way to get good sound quality without making any door-card mods
M :)
W123 560E
M :)
P>S> I used Sony customs to fit under the dash, the 10cm ones give good sound but is appaling for the low-end, hence my 6x9's and sub
The Rest of the Story
MBZ300CD - 6/15/2005 12:33 PM
Details:
» sensitivity 90 dB
» depth 1-11/16"
Finished installing the rest of the stuff yesterday...
Sony XM-2100GTX
2-channel car amplifier
100 watts RMS x 2 at 4 ohms
125 watts RMS x 2 at 2 ohms
250 watts RMS x 1 at 4 ohms
stereo or bridged mono output
4-ohm stable in bridged mode
two 25-amp fuses
MOSFET power supply and output stages
low-pass crossover (50-300 Hz, 12 dB/octave
preamp- and speaker-level inputs
preamp outputs
gold-plated connectors
variable bass boost (0-10 dB) centered at 40 Hz
13"W x 2-3/16"H x 8-15/16"D
Sony XS-L102P5
10" 4-ohm subwoofer
10" subwoofer with 5-sided polypropylene cone
foamed rubber surround
frequency response: 18-2,500 Hz
power handling: 80-330 watts RMS
peak power handling: 1,200 watts
sensitivity: 88 dB
top-mount depth: 5"
sealed box volume: 0.93 cubic feet
ported box volume: 0.78 cubic feet
Q-Logic Box
Sony XS-V1330A
3-way 5-1/4" speakers (pair)
H.O.P. woofer cone with rubber surround
paper balanced-dome midrange, PEI dome tweeter
power range: 2-45 watts RMS (180 watts peak power)
frequency response: 40-30,000 Hz
sensitivity: 91 dB
[8D]
EDIT: All this with no cutting and use of original grills.
1982 240D M/T White
Discussion Starter #12
> What do I think of my Nakimichi TD-400 ?
A GREAT unit (eBay has refurb TD-400s for $160). About $500+ list in mid-1980s (= to $1,000 today). I just use tuner but that is a suberb unit as well. Needs as amp as well.
I am getting MB Quart speakers to match. 5 1/4" rear & 4" front.
Alan
1980 250GD Cabrio
Lanzar Speakers
Does anyone have experience with the Lanzar VX40S. These have a very shallow mounting depth (1.2 inches compared with 1.69 inches for the Sony W4021). Price is about the same but I have never heard of Lanzar.
1 - 14 of 14 Posts
