'80 500SE AMG '80 300SD '78 450SLC '00 Passat GLX Wagon
Anyone know what this tag said at one time, it's worn i know. Only reason it intrigues me is that it looks to have an AM and missing a G but as far as I know my car was given the AMG body kit is all. Regardless is it something important, I can't read German at all so there is a downside to owning a Euro model[:)]. Thanks for the help.
John
'80 500se
'80 300sd
67 300 SEL, 85 500 SEL, 90 420 SEL
Hi,
I think it reads the following in German:
Ab sofort duerfen bei allen Wartungsdiensten die Ventile nur in kaltem Zustand eingestellt werden.
Einlass x.xx mm Auslass x.xx mm
From now on, when the scheduled maintenance is due, the valves may only be adjusted when the engine is cold.
intake valve x.xx mm exhaust valve x.xx mm
Best regards
Hans
W126C AMG 6.0
No question an AMG tag. You've probably got the 276hp version of the 5.0. Congratulations, a pretty rare upgrade.
EuroCoupe - 2/19/2005 10:44 PM
Wow, damn, sweet. And here I was thinking I was just getting a cool looking body. I wonder why no one ever told the previous owner. Helps explain the hideously bad gas mileage as well[:)]
John
'80 500se AMG
'80 300sd
Discussion Starter · #5 ·
67SEL - 2/19/2005 8:38 PM
Hi,
Best regards
Hans
Thanks! I'll make a note of the translation.
John
'80 500se AMG
'80 300sd
