2005 Mercedes Benz SLK55 AMG, 2001 Mercedes Benz E55 AMG, 2001 Mercedes Benz ML55 AMG
:confused: all the warning lights stay lit on my intrument cluster when the car is running?
Just noticed today as I was driving home... I drove about 35miles no problem. What can it mean?
Thanks!
Jerry
2001 E320; 2002 ML500
It is always good practice to replace ALL fuses every 10 years.
If that doesn't fix the problem, check for ground connections (brown wires).
Sergio
'95 E320 190K miles
It usually means your drive belt snapped off. When this happens the alternator stops charging the system and you are running on battery power alone. Now you kept driving and your car did not overheat which probably means your belt is still intact because the belt also turns the water pump, but check just to make sure ;)
Then check your alternator by checking the voltage on the battery. I bet the battery is getting low because the alternator is bad.
