7421 - 7440 of 7489 Posts
1998 SL500 (R129/M119)
I suddenly "noticed" about 20 years of embedded dirt in this back shelf
I'll bet I've put about six or seven applications of this commercial carpet foam for car carpets
And I learned you really need a nylon brush to work the foam in to the carpet
 it seems to get it out but slowly but another hint I picked up on the net when you're wiping it off with a clean rag don't go back-and-forth because you're just pushing more dirt in
One swipe down with a clean Terry towel
I notice it is picking up dirt on the towel  but I may start seeing where I can get this whole thing steam cleaned
The carpets on my storage compartment and in the front footwell carpets are in similar disarray; they will go to the detailer for a deep steam clean. I deep cleaned the tonneau cover by hand with leather cleaner and rags similar to your current process; good result but physically draining...
Hallelujah!! Finally got the coolant level and washer fluid level warning lights to turn off. Had to replace both brand new coolant and washer fluid tank sensors with brand newer ones :(. Stuff happens...
1996 SL500, 2000 E430, 2011 E350
Yeah I'm looking up detailers. After doing this a good 5 to 7 times and there is still dirt ...
i'll bet that hasn't been cleaned in 20 years
Vanity mirrors on 1991 R129 were in terrible condition: discolored, with some unidentfiable blob adhesions, and with an overall tacky feeling that discourages a passenger from even attempting to open up the mirror.
I considered buying replacement mirrors at about $125 a throw. But first I tried to salvage. I used the Novus scratch remover to try to loosen the tacky surface and the tiny adhesions. Then I scraped the surface with a single-edge razor blade. The results were not bad - see photos Rectangle Wood Font Hardwood Flooring
Table Liquid Product Solution Fluid
Ultimately there will come a time when they need replacing, but this restores them to a usable condition for now, and I can put the money into higher priority work on this otherwise enjoyable car...
1998 SL500;51K; 1995 S500 (sold but not forgotten);1992 Miata,92K (sold). 2005 MSM (sold)
Took my 1998 and my wife out for our annual fall color tour three days ago. Actually a short 25 miles out and back that took two hour with a stop for breakfast. The trees were changing and the weather here in Chicago was fantastic! Cool and dry. After a wash and wax, it is time to put the car into winter storage in our garage. Every once in a while I will still pull up the cover and just look at it. Such a mechanical and stylistic statement!
After trying to clean my carpet five times using the spray on foam you get it auto stores, I decided to get it professionally steam cleaned
they were telling me they had to go over it three times as the dirt kept coming up
but to look at this interior it looks almost brand new
The car is a 1996 with 226,000 miles on it
where I just took the pictures the lighting wasn't all that good but I hope I have conveyed what a good job they did
It was money well spent
Sky Hood Automotive exterior Boat Motor vehicle
Tire Automotive tail & brake light Vehicle registration plate Wheel Automotive lighting
Hood Vehicle Sky Steering wheel Motor vehicle
Wheel Automotive parking light Tire Automotive tail & brake light Vehicle
It was money well spent View attachment 2787814 View attachment 2787815 View attachment 2787816 View attachment 2787817
On my to-do list...
I thought the quote of $200 was a bit high but they really worked hard at getting all the embedded dirt out. And even cleaned my door panels and seatbelts I believe. The car looks almost new and the shadows really didn't do it justice
A full interior carpet clean by my detailer is on my list after repairing some stitching in the top.
Your car is beautiful!
1999 SL600 | 2001 SL500 (sold)
I finally fixed my xenon headlights. Changing the bulbs and following the instructions on this site lead to the plate that holds the bulbs to get pushed out of their sockets for the adjustment/ self leveling. Had droopy cross eyed lights for months.
behind the lenses and inside the lighting units were dusty and made the lights look faded so it pissed me off enough to to take the time to open each one up. Popped the bulb holding plates back into their sockets and cleaned up all the white dust thoroughly .
car was from Florida, potentially coke was being hidden particularly in the drivers side??
Hood Automotive tire Automotive lighting Motor vehicle Automotive exterior
Automotive lighting Hood Bumper Bag Electric blue
Well there’s only 1 way to find out, do a line and let us know 😂.
Nice work on that, was popping off the lenses easy?
Just gotta remove the corner lens assembly, then the trim piece below and let it hang, then 3 bolts holding the headlight in place. 2 on the sides and one on the inner side. Then you gotta carefully pry tabs and pry the lenses off and thats it. Don't remove the rubber trim thats on top
Took a drive through the Delta today even with the top down at 60°. Had to check one of the shock towers cause one of the crappy roads launched me like the Dukes of Hazzard --- everything was OK. Getting a chocolate ice cream now
