5881 - 5900 of 5918 Posts
1989 190e 2.6
Ordered a set of H&R springs from Germany, the Sportline springs were just not quite low enough for me in the front. Mechanic threw them on and it looks perfect, but I'm rubbing a lot. Installing fender spacers this week. Also took the opportunity to order a set of Bilstein B8s, should really improve the ride.
My driver side vent housing also finally cracked, I saw a few small cracks but its toast now, ordered a new one of those.
My Sportline suspension seems more firm than stock, and I wonder if the springs have been swapped in the past. #Maranello, would you mind measuring your ride height before the motor swap, wheel center to top of the fender? And if you have a caliper, would you measure the wire thickness of your Sportline springs once you remove them?
W201, W212, W221, & W222 Moderator
'84 Euro 500SE, '85 Euro 2.3-16, '51 Euro 170S, '97 Jeep Wrangler Sport, '15 G63 AMG
If it ain't one thing... it's another. Had a rather normal drive with it today, but noticed what sounded like clutch chatter when I got home. It's an audible noise that wasn't there when I first left, and it goes away when the clutch pedal is depressed.
I will look at it more in the morning.
W201 Moderator
89 190E2.6- 5-speed Manual, 95 E320 Sportsline-sold, 2001 E320 4matic Wagon-sold
When I swapped mine to sportline springs the spring thickness was very similar, just 1mm thicker than stock, But it had more turns and shorter when unloaded. I believe the thickness was 13mm vs 14mm but don't quote me on that.
I'm going to guess that's a broken tang on the clutch release fork.
You are probably going to be correct. Still shifts fine, but I'm not going to chance it.
W201 Moderator
Hello all,, my power assisted steering Has got a sort of Shaking in it,,,Would anybody know what that could be???
Can you describe it further? Shaking when turning, shaking at high speed, etc, etc.
W201 Moderator
Went to the Pick and Pull today as they had a 40% off sale. Picked up all the electronic parts behind the battery (AC relay, FPR, OVP, AC controller, etc, etc) for something like $80. Relays had new date codes and clean terminals. Still looking for the spare EZL. Those are hard to come buy.
Mercedes 190E w201
Doing some small body work, taking care of chipped paint under the fenders and small scratches in body left from the previous owner. Temporary fix before I get it fully repainted in the next year or 2.
1989 190e 2.6
This just proves to me I'm going to need to track down some French headlights for my Almandinerot, looks amazing.
1989 190e 2.6
Had two shops tell me I needed to change the tie rods but everytime I touched them I couldn't feel any play. Firestone refused to align it (Lifetime Alignments) until I change them. Did it last night and boy was I wrong, I don't think the cars ever driven this smooth. o_O
