701 - 720 of 749 Posts
U1450L DOKA
I'm curious - what is this ? It looks like it has some hardware in it. Is it some type of gear bucket that you made out of pipe, or what ? 4 separate shields that slip over something ? Shackles, rigging gear ?
Your new UNIMOG looks great.
Plant Tire Automotive tire Wood Tree
U1450L DOKA
A couple more. On the inside of the shroud, after sanding and painting, I put a few coats of rattle-can bedliner
(Herculiner), in an attempt to seal up the edges of the layered sheet metal, and provide a little extra protection in the Air Blast Zone.
Time will tell.
Sorry about the double post of the Before photos.
Special skills at work.
Automotive tire Tire Wood Carbon Automotive exterior
Automotive tire Wood Automotive exterior Bumper Rim
Bumper Automotive tire Automotive exterior Automotive lighting Fender
Gas Tints and shades Bumper Composite material Electric blue
U1450L DOKA
During and After.
Still miles to go - found wiring and airline issues.
Sexy Photos of those later.
Automotive tire Hood Motor vehicle Tire Automotive exterior
Hood Automotive tire Motor vehicle Bumper Vehicle door
Automotive tire Motor vehicle Automotive exterior Auto part Gas
Automotive fuel system Fuel tank Automotive tire Motor vehicle Automotive lighting
Automotive tire Motor vehicle Plant Bicycle tire Rim
Motor vehicle Automotive tire Rim Automotive design Engineering
Green Automotive exterior Hood Automotive tire Eyewear
Circuit component Font Auto part Tool Electronic component
Motor vehicle Hood Automotive tire Automotive design Automotive exterior
Automotive tire Motor vehicle Hood Automotive lighting Automotive design
85' U1300L Holset Turbo VA A/C, 66' Propane 404.1 rock mog, 1975 416 Doka, G500, Volvo C303
That gives me night terrors of when I still had the mech fan. Got so tired of repairing that system. Draining and resoldering the radiator was the worst repetitive part of it.
U1450L DOKA
I’ve had zero problems with it.
My Buddy had the pulley / fan frame break, sending the fan into the radiator, which was a mess.
I’m sticking with it until I find a reason not to.
1250v
New ujoints on my left front cardigan joint.
Wheel Automotive tire Tire Tread Wood
Wood Automotive tire Working animal Auto part Fur
Automotive tire Wood Gas Motor vehicle Automotive wheel system
Organism Road surface Sand Soil Concrete
Hand tool Wood Metalworking hand tool Tool Wrench
Automotive tire Motor vehicle Wood Automotive wheel system Machine
Motor vehicle Combat vehicle Wood Automotive tire Machine
I guess I didn't take pictures of the portal back on the axle. I will grab them tomorrow. I just need to change grease fittings and bolt it back together.
1250v
That might be the wrong term, that's what I have heard the double ujoint between the axle and portal called
The word you are looking for is Cardan Joint. Cardigan is just warm and fuzzy.
Well then, carry on.
Watch the radiator supports soldered to the radiator at the top edges though. And keep inspecting the fan frame. I think the setup is fine assuming everything is in working order but the slapping belts and potentially off balance fans can tear it up quickly.
U1450L DOKA
I just had a moment! I just made a mail run on a dirt bike 1.5 miles to the mailboxes and back. I locked the gate and decided to max it out on the short straight run inside the gate. 3rd gea
Cloud Sky Automotive lighting Automotive design Lighting
r I quess, ball cap, no helmet (D’oh!) . I’m at a good clip and all of a sudden a big Muley doe, about as big as they get around here, launches out of the bush, coming uphill from my left, nearly T-boning me. She lands next to me, a little ahead, maybe a foot ( less, I think) away from the handlebars….we are both hauling.
I hit the brakes and she shot across in front of me and up the hill. Yikes !
I’m still wound up ! She had a beautiful dark fall coat…
New helmet sitting on the shelf just inside the door, of course.
U1450L DOKA
It would have to be the largest doe I’ve seen all year…I
Think. Maybe my eyes just got big !
