1998 ML320 and 1990 190E
Help. I found a mess of oil all over the front of my engine. After cleaning up what I could I found the oil is leaking from the filter housing. There is a square finned section attached to the housing itslef and the oil is leaking from between them. What is the square fined piece and is this something I can fix? Is there a gasket bewteen them or is it all one part that has maybe cracked? Any suggestions are appreciated. Thanks.
ml500 w163 2002
pics would be useful for us to help you.
· Outstanding Contributor
2006 ML500 2002 ML320
If you did an oil change or just had one done, it could be the top O-ring on the filter or the large nut at the bottom of the filter housing (#8 in diagram).
Or as Drewbush said the O-rings in between the cooler and filter housing. The two seals in between are #112 184 02 61 & 112 184 03 61 and the seal at the bottom of the housing is 112 184 00 61 (#6 in the diagram). Here are the instructions.
Discussion Starter · #5 ·
Great thanks. I predict the O rings because I can see the oil seeping up and out of the seam on top between the filter housing and the heat sink. I'll be pulling it out tonight. Results to follow. THANKS
