It might be leakage between windshield and rubber gasket, it is not easy to detect using a garden hose, since it might take a while before the water leaks through. I fixed this with a window sealant compound, around the hole window<br> <br> for the 123/126 leakage in the rear window is also common. This leakage is between the gasket and the body, and can bee seen in the trunk.<br> <p>proxy2.kvaerner.com
