71 280se 3.5 Cab, 06 C230, 06 ML350
Anyone know where I can get my hands on the thin Grey colored opencell foam, I assume, material used to wrap some of the under dash wiring? For example, the connection, that plastic plug, between the HU speaker wire and the speaker wire. Mine is all crumbling and starting to fall down. Especially when I do something under the dash.
This is the stuff MB uses to pad the vynal area over the convertible cover. I used it to also replace the foam seals on my AC ducting. If I recall it was cheep.
Great Thanks. Got it from the dealer I assume (saw the MB tag on the wrapping)?
1978 280slc
All that foam stuff in my car is turning to dust also, good topic to bring up as we'll all end up having to repair this stuff eventually. Good luck finding your foam! Maybe check out an auto upholstery shop.
