2000 E430 4Matic
For the past couple of days when I start the car the radio will be on but not show any digital output. Then when I shut the car off, the radio will keep playing.
If I shut the radio by pushing the button, and turn it back on, the digital comes back and when the key is turned off, the radio shuts as it should when the key is removed.
1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Pull
the radio...........have the code handy to reset it.........disconnect it from the harness or remove the fuse.hook it back up and enter the code per your manual.Sounds like a comm error and this may reset it.
ohlord:bowdown:
cluster/radio/climate tools $25 boxed set delivered
or if you don't want to pull the radio do the hard reset procedure in the diy section.You will need to resync all systems afterward and enter the radio code and sync the windows and sun roof and steering wheel angle sensor.
2000 E430 4Matic
Is the radio a press fit like the cluster or is there clips somewhere?
If I just pull the fuse at the panel, I would then have to turn the key on so the computer "sees" no radio, right?
