Don't know much about Mercedes alarms, apart from they don't seem to last long in my cas...
Don't know much about Mercedes alarms, apart from they don't seem to last long in my case.
You could try leaving the battery disconnected overnight to drain any back-up memory,it may reset it self to normal. Other than that a decent auto electrician should be able to either repair it, or if worse comes to the worse disconnect the system.
