1 - 11 of 11 Posts
Moderator
SL55, 300SE, GL450, Daytona 955i
out of 1995 W140 (S420)
working fine
the first 175 dollars gets it!
hurry up and buy it before 5pm. :)
paypal: [email protected]
Moderator
Discussion Starter #2
its packed and ready to go... anyone?
Moderator
no.
the 92-93 has tuner built in it. that's why they break 10 times more often.
Moderator
140 820 22 89
S600 C140; 200E W123; 200D w124
Thanks, would it be compatible with a 140 820 11 89? I have a 1432 Becker with two parts: front control, tape unit and in the trunk tuner. According to Becker site the model in my car, 600SEC 93, should be a 140 820 00 89 but mine has the above mentioned. Got any pic of the box and the connector from tuner and to speakers? Is it a 27 pin conn? Is it in working order? Thanks.
Moderator
you need an amp with the built in tuner. the jack is the same, but you probably going to need the same amp as what you have.
check with the dealer to be 100% sure...
Mercedes 93 300SD
AMP
I own a 93 300sd which uses the same amp as yours, the tuner is not with this as it's a separate box below the amp. They used these on the 92 & 93 models. The part number for the amp is "140 820 00 89". I just bought one today from a San Diego junk yard for $100 guaranteed to work. If you do a Google search you’ll find places that want $550 to do a rebuild.
Factory Car Audio Repair For All Makes and Models - Mercedes S/SL/SLK, C/CL/CLK, Car Stereo Repair Estimates and Bose Car Stereo, Speaker / Amp Repair
Moderator
Discussion Starter #11
the one for sale will fit 94 through 99 W140s.
if you go to the link above, it looks like the first picture there.
1 - 11 of 11 Posts
