1999 C43 AMG, 1998 C43 AMG
Alright, this has been going on for 2 years, but I'm only now looking into it.
As the title implies, I'm having a hard time getting the car to warm up; both the engine and the interior. Having a weak interior heat isn't all that weird. You typically just replace heater core = done.
But my engine has a hard time getting hot, too! It struggles to get above 40 degrees! If I leave it running to warm up, in about THIRTY MINUTES it will reach 80 degrees, plus the heater will be working noticably better (but not perfect). But as I begin to travel down the road, the engine and heater temp quickly falls to lukewarm.
Also, a mysterious coolant leak I can't find. It's making no puddles, but it has a slow leak somewhere making me top it off every couple weeks. Perhaps this is related...
Not burning coolant. Already fixed the head gasket. Engine runs like a champ. But I think I have the only m104 on the planet that is running TOO COLD.
2013 VW Golf Sportwagen TDI, 2011 Mazda 2, 2000 E320 4Matic Wagon (retired),1994 C280 (retired)
The very first thing that would come to mind would be a thermostat that has failed in the "open" position. I read your post twice to see if there is any mention of a thermostat having been replaced and I don't see it. I hesitate to offer this advice because I know you are an advanced DIY'er and have in all likelihood considered the thermostat. But I have delved deep into the evil that is the cooling system on the M104, and this is the only reason I can think of that a car that is otherwise working properly would fail to reach operating temperature in a few minutes.
2001 CLK55 AMG, 2002 C32 AMG
sounds like a thermostat issue to me, at least to solve the engine coolant temperature issue. maybe there is a separate issue with the heater as well, but you wont know until you get the coolant hot.
the mercedes thermostats are designed to fail open. mine did it. i say replace the thermostat and coolant and see how if it helps.
Wow. I'm kind of embarassed.
I had no idea the thermostat fails open on these things.
Needless to say, that fixed it. Hah.
Thanks for the tips guys. I was THIS close to replacing all of the hoses on my car, as well as the heater core.
ML320,C230, F250, Bayliner, Mountain Bike, Fleetwood Motorhome etc...
My thermostat stuck open and I had the same problem as you but I didn't wait 2 years to fix it... lol
