my 1999 clk's headlight is white... is that xenon? or is it non-xenon? cause i always thought non-xenon r the yellowish kinda color.
can someone post a pix of xenon headlights and non-xenon headlights? thx
so if i have the WHITE kinda headlight, and it is broken. can i buy the non-xenon ones and just swap the bulbs because my xenon headlight still works... the outside cover and some of the inner plastic are cracked.
1985 300sd
Xenon, also know as hid is a lighting technology which has been around in passenger since the mid 1990s. It is provides a significant light increase over halogen passed lamps. Xenon lamps are designed to last for around 2000 hours!! NO, if one of your headlights is out, you cannot just plug a halogen bulb into a xenon based housing, the bulbs have differnt sockets. And if you already have xenon headlamps you would not want to go back to halogen, because you would definently regret it. Check ebay for a used housing.
SL500, CL55, E350, E320
Depending on if you bought your car new. If you did, and the light was "white", then it is xenon.
On the other hand, the previous owner might have put cheap bulbs in there.
The picture below is one of the real xenon bulbs. The first pic is D2R type and second pic is D2S type. These are expensive but affordable. As mentioned, they last about 2000hrs so it's not that bad. Ebay sells them for less than $100 a pair (new).
