Steps already taken:
Changed window seal
Cleaned all drains connected to trunk area
Rear C pillar covering vents checked for rust or stuck dirt...cant see any/no water behind c pillar trim!
water still rolling from side to side below tray/parcel shelf. Also cleaned and re-fixed trunk lid bidding/rubber and adjusted metal work around shut lines of trunk lid. Cant find any water traces originating from the trunk lid or its hinges and water is showing up below main parcel shelf area between/in the middle of where the speakers end and the trunk lid begins. Did a bucket water test with guy inside trunk with a torch light no leaks...but with ultra heavy showers water still comes in!?
Should rip out rear c pillar trim? and or change the trunk lid rubber although I cant find any water traces originating from trunk lid or its hinges!?
I think you have to consider carefully removing the C pillar trim! (Don't rip stuff out and make more work for yourself)
