560SL,380SL
Does anyone know if it is possible to remove the pressed-on water pump pulley on an M116 engine (for serpentine belt conversion?). The M117 AFAIK has a flange on it and THAT is very simple. Thanks.
1990 420 sel 213,800 replaced water pump and radiator; the timing chain good
It had to get on there someway. So there's someway to take it off. My 1990 420sel has four bolts to take off the water pump pulley. Is that the m116 engine you're talking about?
560SL,380SL
Nahh, it's pressed on. I'm wondering if it can be done without damage. I'd like to set up a serpentine system.
w126
It's a tight fit but it can be removed. I don't think it's a press fit. It will come off with a little encouragement from a rubber hammer.
