hi every one, i have a 2014 cla 250, the water pump is not circulating the coolant at all. i read some where that what goes wrong with these pumps is the linkage of this actuator. what i would like to know is in what position (in or out) does it allow coolant to flow. pump replacement is a big ugly job and if i can fix it by manually moving the valve and by-passing the actuator then that's what im going to do. thank you for any help
