1 - 11 of 11 Posts
1998 ML320 (W163), 2004 S500 (W220), 2003 E500 (Girlfriend's W211)
Hello all, I have water pooling in my trunk (boot) where these rubber grommets go. I know this obviously means I have a water leak somewhere in the trunk, however, how would I go about draining the water that's already there? I got under the trunk area as well as I could and couldn't see any obvious body plugs to drain these areas. It's on both sides of the trunk as well.
2695816
2695817
S500 4Matic 2005, S550 4Matic 2013
Adrian,
I know for a fact that the seals on the taillights are known to leak on our cars so there could be a possibility that the water is coming from there. As far as how to drain it, sorry bud can't help....
Adrian,
It's possible, however these grommets that I pulled out are more towards the front of the vehicle near the fuel tank. It's possible that it would still have something to do with it though. I replaced the taillights somewhat recently because of a faulty Chinese set that a previous owner installed 🙄. When I called my local dealership about replacing the seals (I decided to just buy a used set on eBay), they told me that the seals themselves were NLA but that I would be able to buy the entire taillight assembly that would include a new seal for an exorbitant price. Anyways, the seals seemed in decent shape when I installed them. I'm not sure where other common places for the trunk to leak are on the W220 though.
Discussion Starter · #9 ·
Which trunk seals? The soft rubber seals or is there other seals that I might not know about? I also haven't heard of the filler seal...I'll have to check that one out. I'm still trying to find a way to drain the water out of these holes also. I would assume that there would be another grommet somewhere on the underside. I may end up just sucking it out though. Not sure yet
2003 S500
Is there standing water at the bottom of the fender wells on either side?
Discussion Starter · #11 ·
None that I could find, just in those body grommets that I pulled out.
1 - 11 of 11 Posts
