1 - 12 of 12 Posts
1992 190E 2.3 aut. white Benz
My son is 92 , 190E 2.3 auto. white Mercedeces.
He has a very big problem , there is a water leakage . I have attached the photos of leakage area. I think that hoses for AC's disposal water however my car loosing engine water from there.
I have recently changed cap of engine water case then leakage amount inreased.
By the way it is heating system works very well, but AC doesn't. Morever leakage is independent whether I use heater/AC.
Thanks for all answers
Ray
IR MODERATOR
1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
those are transmission lines and they shouldnt leak water...
the water is coming from that black hose in the deep . It is more easy to see in the first photo.
IR MODERATOR
its a drain hose for the hvac
What can be reason for this leakage... Heater core or something else which is connected drain hose...
IR MODERATOR
is it water or coolant? it might just be condensation from the ac
IR MODERATOR
it could be rain water, etc...its normal, if its coolant then its a bad core or something like that.
it is coolant. because I have to add water to engine after two hours drive.
IR MODERATOR
heater core or a bad hose near the heater valve.
How can I understand the problem is the heator core or heater valve... Let me change my question do i have to dismount all the dash and reated parts to reach both parts...
By the way, thank you for your answers...
IR MODERATOR
nope, remove the cowl under the wiper and you can see the valve, the core, you would need to remove the dash. my money is on the valve.
Discussion Starter #12
Hi again...
yes my problem is heater valve, I checked it and there is a serious leakage on it. I hope that is the only problem. I ordered new part probably I ll be fixed in couple of days.
Thanks again help
Have great weekend :)
1 - 12 of 12 Posts
