Water and oil in the air filter
777 Views 3 Replies 3 Participants Last post by  YellowSLK230
2
Why I found water in the air filter? You can see it in the right bottom corner of the filter pic.
Sometime it is mixet to oil or it seems to be oil and water.
What does it mean?
PVC?
What is that valve?
I think he meant PCV valve, Cixi. Positive Crankcase Ventilation valve. The manufacturers often route the blowby gasses in the crankcase area into the incoming air stream so that they will be burned by the engine, to reduce air pollution. The PCV valve insures that air from from the crankcase goes into the air intake, but fresh air does not flow in the opposite direction, bringing dust with it into the crankcase.
