2003 SLK 230. Speer pulley kit. Depo euro headlights with led. Led taillights
Hi,
I would like to know if the wastegate closes completely at wot. Does it require periodic reset / adjustment? Thanks.
2002 SLK32AMG,1995 E320 Cab 1990 300CE(Gone).2002 ML320 (Gone)
Wastegate ?
SLKs have superchargers. A wastegate is paert of a turbocharged system.
Moderator
1998 SLK 230
WIS says it does stay shut at wide open throttle... i was going to try using a mechanical bypass valve (i sometimes look for them on ebay) if i can get one cheap i might try using that one day which is actuated by vacuum to rule out the ECU playing with it... still yet to find a cheap one to test
