1 - 20 of 35 Posts
· Super Old Fart Moderator
2002 ML320, 2010 F150 Crew Cab
This is my headlight on the 2002 ML320. I wonder where else this is lurking?
Automotive tire Helmet Motor vehicle Automotive design Automotive lighting
· W163 and General M Gremlin
Knock on wood.'
Did not see this when I opened mine up a couple of years ago replacing the xenon servo shaft.
2000 ML55 sold? 2013 ML500,? 2017 C43 AMG,1929 Victory 6 roadster, 1927 Dodge 4 sedan, 1929 Dodge
Mine were the same it’s just from the heat of the headlights
Discussion Starter · #11 ·
Nothing to see here. Almost all old headlight wires get like that from the heat.
Using your reasoning then the wire around the engine harness should have let go years ago. Much hotter than the headlights.
2001 R129 SL500, 2002 W163 ML500
I find bio-degrading type wire in the taillight assembly, going to the side marker light. 2002 ML500. And I get to flex the wire to replace side marker bulbs...
95 SL600
like the Tesla business model that salvages 1 year old cars for light cosmetic damage, and won’t allow reusing most of the taken off parts whether they are in good condition or not, if they do fix it.
They don’t want you to fix the car, and will turn the car off if they don’t like where the car is. You don’t own a Tesla, you pay for the right to drive it. Body shops don’t fix them, just take them apart and write up $35,000 bumper repairs, no structure damage,
1999 E430; 2005 ML500
Your reasoning is understandable. Yet, we see that insulation frequently deteriorates in headlights, yet not in engine harnesses. This could be due to 2 reasons:
1. Your premise is faulty, and headlights frequently get hotter than the ca. 220F found on engine tops, or
2. The current in the headlight wires causes them to overheat.
let’s see the answer:
Discussion Starter · #17 · (Edited)
You left out no. 3.
3. The company that manufactured the headlights used ‘bio friendly’ wire instead of the wire used in the rest of the vehicle.
As per the picture, this isn’t a current problem. They just crumble to dust. I just ordered two new headlights so problem hopefully will be fixed Wednesday evening.
1 - 20 of 35 Posts
