BAS/ESP, ETS, ABS lights came on parked came back out and needed a jump start, lights reset drove for 2days lights on again, anyone out there familiar with this kind of problem? Recently passed inspection but brake pedal is low, they said I had 50% pad left but I do get a brake squeek in rear wheel,brake fluid is full. Should I replace the brake pads?
1998 E320 RWD Metallic Black; 2006 BMW 530xi; 2011 E350 4Matic Sport
I would start with your battery. It is common in all MB that when battery is low the BAS/ESP, ETS & ABS lights come on. From what you are saying, it needed a jumpstart so check that first. The second thing I would check is the brake light switch. A faulty switch will usually trigger those lights.
Thanks for the response, I will get the battery checked to see what the amperage is reading & proceed from there.
