1 - 10 of 10 Posts
It's getting kind of cold in my area and not having remote start is inconvenient.
I was wondering since I had 2 keys if I could start the car and leave the key in there, would I be able to reliably lock it and unlock it later with the other key?
Zotye Auto 1.5T T600 2016
This should be no problem. Do make sure both keys operate correctly first of all.
2002 C32 AMG
I believe you can use the mechanical key to do the same. Start car, hit lock on dash for all other doors, manually lock driver door?
It wouldn't work with the 2nd remote so I used the interior button, then the mechanical key for the driver door.
It was 23deg this morning, which might not be low to some people.
You know that Benz do not recommend an idling warm up? - needs about 1200+ rpm to ensure bore lubrication.
Oberoi
2002 C32 AMG
I tend to rev the engine up to 2k for ten seconds or so after cold start when RPM's drop to increase oil pressure, and provide initial lubrication.
We used to do this many years ago but with modern engines the oil pressure is at max by the time the engine revs drop anyway so really it is a waste of time and may actually (depending on outside temperature) lead to engine damage.
2012 E350 :-) 2002 E320 (sold)
just for grins
Years ago I had a GMC van. I wanted to leave the dog in the van, but it was too hot outside so I decided to keep the van running with the AC on, remove the remote from my key, and lock the doors. That seemed simple enough until I tried using the remote to open the van. no joy. So there I was in BF new jersey with my dog locked in the running van and me outside unable to open the doors with the remote.
On another note, one of the people I work with let her car warm up in her driveway while she went inside for something. When she came outside her car was gone. Someone stole it from her driveway. That was bad enough, but when the insurance adjuster asked her, "What did you do to prevent your car from being stolen?" all she could say is that she left her keys in the car with it running and she went inside her house. Fail.
2002 C32 AMG
When you start to drive engine averages around 2k RPM? How is that any different? Initial start creates more wear due to the lack of lubrication. It only takes several seconds for full oil pressure correct?
1 - 10 of 10 Posts
