Hi, I think my warm up regulator has gone faulty on my 1984 280CE
She Starts up from cold okay but very very rich, carbon soot coming out the back and really really fumy...!!!!
Then while warming up tickover is quite erratic up to 1200 rpm and down to 600 rpm and running very rich.
Then when warm, quite low and very lumpy tickover and still runing very rich.
She runs okay when actually driving along, I have also noticed fuel consumption is also very high.
Do these syptoms fit with the WUR failing....? I have looked at previous posts and it would appear so.
I am going to check this thing out over the weekend, Nutz 4 Benz advises to check for voltage at the connector plug, which I will do - If there is no power, is there a fuse maybe to check...? Any other suggestions as to how I can firstly determine that it is the WUR at fault would be appreciated.
MB garage want $3500 for a new WUR to come from Germany, but my mate is breaking a 280E same year as mine - will the WUR fit and suit mine...?
If it is the WUR and I can change it for the new/old spare from the 280E - will I have to do anything other adjustments or should it just work....?
Appreciate your help,
Martyn.
Martyn.
