Hi all.
Ive just bought a 1988 280GE SWB 4-speed auto g wagon.
it’s in good condition and running well. One thing I’ve noticed straight awayis that the odometer and trip meter are not turning / registering miles. All other instruments are working fine including speedometer. All are mechanical rather than electric
I’ve done a bit of exploring and it seems that wear on the gears within the speedometer can cause this issue and is common among vehicles of 70s / 80s.
Has anyone encountered this issue and any suggestions on approach to repair? Needless to say, step 1 is pulling out the instrument cluster!
Thanks in advance all
96 G300DT
It is a cracked gear in the odometer. Once cracked, it loses it's grip on the shaft and can't turn it. I believe one can get replacement gears, though the work is a bit fiddly. The hardest part is opening up the can. There are certainly shops that do this for a living.
Thanks mate. It looks easy enough to take out the instrument cluster (looks to be two small screws, one either side of the cluster housing). I’ll see if I can get it out and identify the cracked gear
