You don't have to remove the front bumper here. You work from behind and unbolt the front fender liner. I will attach the relevant WIS procedures.
It would be easier to jack up the car and remove the front wheel first. Then start to remove all the fixings for the front section of the liner. The WIS infers that if just the front section is unbolted, you can reach inside to remove the DRL from behind. Maybe not - you will find out.
There are clearly two versions of DRL, which are both shown here. The DRL fixings are different for the 2 versions. Regarding the 'expansion clips' (which are used by MB on many other models to hold paneling in place), use a screwdriver to pop up the center pin and the clip will then come out easily. It is reusable.
