B170 2006
This is my first winter with my B170 from 2006 and I'm a little surprised how AC is working. During summer AC was working perfectly. Right now, with temperatures below zero, AC is cooling only when I put it on blue dot (max cooling). When I put even one step more the air is getting hotter. When I put on 16C - it's warming. The previous owner said that it's working that way - car "knows" there is a -4C outside, so to get a 16C inside the cabin you need to get hot air. During summer I drove on 20-22C and the air was cold. Could you please tell me is that really how the AC works on this car? Or is it due to the low refrigerant and I need to get it recharged?
· Benzworld Staff
Night Crew......2006 B 200 .....& Audi A6..
Welcome dragonek !
If you could do all the potential readers a favor,
Please complete your BW registration profile
so members may better assist you, seeing and knowing what you drive...add your contry in the proper location asked for and also hit "save"..
Goto your ===> user CP profile====> click on your icon (top right corner of the webpage) ----> then click on "Account Settings"----> goto Account Details----> add vehicle details---->
ADD your make model YEAR (i.e. 01 ml320) into your Profile ----> (MUST) click save at the bottom of that page.
YOUR vehicle info will then show/display under your username & avatar (on the left side) once it is completed. If it doesn't display under your Avatar, it wasn't saved.
Members will then see your avatar car info & know what you drive if replying.
· Outstanding Contributor
smart EQ W453 2020 sold A200 C169 2006
The setting on a/c controls are not the temperature of blowing air - it's the desired temperature inside the cabin.
If it's minus 5ºC outside, even setting the a/c on 13ºC will get you a warm air ... it's a very simple concept 😉
Once the cabin is warmed up to the desired temperature, the air coming in will be much cooler (but still not straight from outside).
Every a/c system I've encountered for the past two decades works exactly the same, although to be fair it was mostly Mercs :ROFLMAO:, with exception of some hired cars during summer holidays...
B170 2006
@ MB•David
Thank You for your help. Previously I was driving Hyundai i30 for couple years and a/c was working differently. A/c knob actually didn't have temperatures - first half was blue the other half red. When I put in blue, air was always cold. If I wanted to have a hot air I had to put on red part of knob. Cold winter or hot summer - a/c was working exactly the same.
No worries :)
The MB a/c is actually quite good, you'll just have to get used to a different approach ...
Setting a desired temperature makes more sense to me - it is sort of "set and forget" system, where you don't need to constantly adjust the a/c - I like it.
I normally only change mine twice a year: summer / winter and the settings alternate between ~ 18ºC and 22ºC.
