Hi All!
And God bless
For two years i been struggling with the check engine light and the Fault codes.
I have changed and bought a brand new secondary Bosch pump and relay, and still the engine light is on.
these are the reading i'm getting please help
0810
Mil on&stored &current Malfunction of secondary air injection at right / left bank of cylinders
function 0814-0060
and please check if my car with the vin number
WDD2211711A090846 has the idle gear problem or might get it
My engine code 273961 30 080839
thanks in advance
Hey Y'all
Please anyone check these readings im getting. Just did a computer scan on my W221 s class 2007
these are the readings / faults code im getting.
thanks in advance y'all God bless
Fault Codes(1)
9001 Stored&Current
Control unit N93 (Central gateway control unit) is defective.
Fault Codes(2)
0810
MIL ON&Stored&Current
Malfunction of secondary air injection at right bank of cylinders (function chain) (P0410)
0814
Malfunction of secondary air injection at left bank of cylinders (function chain) (P0410)
Fault Codes(1)
9044 Stored
E17/16 (Left front footwell lamp) E17/15 (Right front footwell lamp) - Check line at pin 3 of coupling 1 of component N72/1 (Upper control panel control unit) for open circuit.
Fault Codes(1)
9044 Stored
Fault Codes(6)
9103 Stored
Component B14 (Ambient temperature display temperature sensor) or line to component has short circuit or open circuit. At extremely low outside temperatures, i.e. < -40 °C (< -40 °F), a fault may be entered even though the component and the feed line are OK. The fault entry should then be ignored and erased.
Event 9117 Stored
No CAN message was received from control unit N69/1 (Left front door control unit).
9042 Not checked
Component M5/1 (Windshield washer fluid pump) has an overload or short circuit or the line to the component has a short circuit or open circuit.
90B0 Not checked
Component E2e1 (Right high beam) is faulty or the line to the component has a short circuit or open circuit.
90B1 Not checked
Component E1e1 (Left high beam) is faulty or the line to the component has a short circuit or open circuit.
9145 Not checked
Component N10/1kK (Wiper park position heater relay) is defective or the line to the component has a short circuit.
Fault Codes(2)
9060 Not checked
Component E3e5 (Left rear fog lamp) is faulty or the line to the component has a short circuit or open circuit.
9131 Not checked
Hall sensor of component M24 (Rear window blind motor) is faulty.
Fault Codes(3)
9211 Stored
The module carrier for the seat cushion is defective.
9210 Stored
The module carrier for the backrest is defective.
9200 Stored
Fault Codes(7)
900A Stored
The mirror heater has Open circuit.
900E Stored
Component E6/5 (Left exterior mirror turn signal lamp) has Open circuit.
9015 Stored
Component E17/3 (Left front door entry/exit lamp) has Short circuit.
9017 Stored
Component E17/19 (Left front door warning light) has Short circuit.
901A Stored
Component Door handle recess and trim strip illumination has Open circuit.
Event 9037 Stored
The signal from component S22 (Left front seat operation switch group) is implausible or no signal.
Event 9038 Stored
The signal from component S20/1 (Driver power window, outside mirror and trunk lid switch group) is implausible or no signal. ( If there is no specific customer complaint, ignore fault code . )
Fault Codes(1)
900A Stored&Current
Fault Codes(2)
9395 Stored&Current
A31/1m1 (circulation pump) : Short circuit to positive or open circuit
951D Stored
A32n1 (Blower regulator) : LIN bus communication error
0810 Malfunction of secondary air injection at right bank of cylinders (function chain) (P0410)
Frequency counter 1
Kilometer reading 42295 miles
Vehicle power supply voltage 13.9(First)/13. V
9(Last)
Vehicle speed 0 mph
Engine speed 705(First)/717( 1/min
Last)
Engine load 13(First)/17(La %
st)
Engine temperature 178 °F
Air mass 29(First)/36(La %
st)
Air mass flow 25.8(First)/33. kg/h
6(Last)
Temperature of intake air 113 °F
Ambient air temperature 104 °F
Ignition angle at cylinder 1 18.00(First)/15 °
.00(Last)
Lambda control, before TWC right 1.00(First)/1.0
0(Last)
Lambda control, before TWC left 1.00(First)/1.0
0(Last)
Lambda set value 2.00(First)/1.1
0(Last)
Additive mixture correction, -1(First)/-2(La %
right st)
Additive mixture correction, left -2(First)/-3(La %
st)
Right multiplicative adaptation 0.94(First)/0.9
correction 7(Last)
Left multiplicative adaptation 0.96(First)/0.9
correction 8(Last)
Camshaft position 'Exhaust' Right -21.0(First)/-2 °
1.0(Last)
Camshaft position 'Exhaust' Left -20.0(First)/-2 °
1.0(Last)
Camshaft position 'Intake' Right 36.0(First)/35. °
0(Last)
Camshaft position 'Intake' Left 36.0(First)/36. °
0(Last)
Intake manifold pressure 350(First)/420( hPa
Last)
Status 'Secondary air system' Active(First)/A
ctive(Last)
Position of tank vent valve 0(First)/0(Last %
Fuel tank level 22(First)/22(La %
st)
Fuel tank pressure difference 36(First)/36(La hPa
st)
Ambient pressure 970(First)/980( hPa
Last)
Position 1 Throttle valve 16(First)/16(La %
st)
Time since engine start 314(First)/164( s
Last)
Operating time 278916(First)/2 min
79732(Last)
Driving distance since fault 52 miles
memory was erased
Driving distance with Check 0 miles
Engine indicator lamp ON
