Does someone has experienced with S350 (W221) the display show ABS,ESP&Run flat tyre currently unavailable ? But the message will goes out when you drive gentle corner. What parts should be changed ?
You could ask this from the W221 forum.
Have you worked with the car recently, battery disconnected or gone flat? Hit the curb with a front wheel?
Before starting to buy parts, the car should be diagnosed with Star. Could be an ABS sensor issue.
Zotye Auto 1.5T T600 2016
Check the tyre pressures, if you have run flat tyres then you may not notice that one is punctured. Tyre low size is different from the other 3 so lights on but when in a corner the wheel moves at correct speed.
