161 - 174 of 174 Posts
Thank you for the information. That will help a lot. As GPS goes, GPS cables are simple 2 wire cables. If I can convert the connector going to the original antenna, what would be the reason that it wouldn't work ?
Finally did it comand upgrade
Well I did it with a lot of hassle at first, I originally bought an s320 2004 for parts, had a widescreen comand but used the most system, after ripping out the fibre optics and other wiring looms, got it all working, the problem was that I had a Bose sound system so had to chop and change the speaker wires, but because Bose speakers are lower resistance it sounded crap. So I bought a 2003 comand, rewired my speakers back to the Bose amp, swopped a few wires in the connectors, soldered the gps antenna wires to the blue plug, turned on and hey presto all working, steering wheel controls, dashboard display, sat nav and the best bit my bose sound system, so for anyone trying to upgrade from a standard comand to a widescreen with Bose sound system you have to buy the 2003 command, only that one works with d2b it's not as good as the 2004 head unit but it sounds better, the 2014 Dx navigation disks work in it too, good luck.
I am about to undertake this, i. e. a COMAND 2.0 wide-screen installation, on the project 2000 S500. This is because the project 2000 S500's COMAND 2.5 has gone kaput. Looks like I'll be soldering the GPS antenna wires to the blue plug. Thanks for the heads-up on this.
I am going to try this conversion also on my 2001 S500.
Chris, is the "SPEED SIGNAL CONVERTER" still available on your website?
David
Not made anymore..Thats the big problem...
Yep, so I learned a couple days ago. Emailed you and nope, not available anymore, unfortunately.
According to Simon Harper's post, apparently nav does work after the solder job. Worth a shot. The only other viable alternative I see is a rip-and-replace with one of those new Android units, which come with their own GPS antennas anyway.
Discussion Starter #170
Yeah its get a gps signal but it still dont know your driving without the speed signal.
For what purpose are you using it? To convert what to what?
Cause I don't have gps- speed signal converter to starts- Chris from sweden will not have any more converters. Cd works ok. GPS Antena too. I have got empyt C2 pin 6 slot- speed signal.
Probably i need CXS CAN Speed Pulse Converter cause nawigation calculate route but there is no move on the screen.
W221 & Audio Moderator
OK, that clarifies the matter. However, I am sorry not to know the answer. I hope someone can help.
About this Discussion
32 Participants
Skylaw
Mercedes-Benz Forum
Full Forum Listing
