81 - 100 of 174 Posts
Cool thanks. I saw its around $500. Where can this be installed? I see that its only half din which is cool. Can it be installe upright. like in the center console or is did you have another place for it to be?
Having seen block try this and be successful, I am even more inspired to ry this, however, going from Block's experience, I would want to map out the pin moves so that it is really clear before I start as the car is used as a daily driver and could not be off the road for days on end.
The issue at the moment, is that I saw another 1999 s320 owner with a standard radio cassette (as I have) had completed a transition from the standard radio cassette to a Comand 2.5 and then more recently to a Comand 2.0. However, asking around, I keep getting told that moving from a 1999 s320 without Comand to installing a Comand 2.5 or 2.0 would not be possible. Can anyone help inform me as to whether this is possible or not?
I have posted photos of my radio cassette unit including existing wiring on Page 5 & 6 of this post:
http://www.benzworld.org/forums/audi...d-2-5-a-5.html
Is someone able to let me know which connectors on my unit are which? I have 3 block connectors:
1. Top connector with 3 cables coloured Green (top far left pin - assume it is pin 01), White (bottom far left pin - assume it is pin 06 and White bottom and second from far left - assume it is pin 07)
2. Middle connector - speaker cables
3. Bottom connector - Power, audio mute, ignition, etc.
And, whether these could be wired easily to accomodate a new Comand 2.0 unit, or is it just too much of a headache to complete? I am not worried about TV or sat nav - though if they were easy to have working that would clearly be great. My main interest is in radio, CD and having a clear display and modern unit.
If anyone is interested in completing a wiring diagram of my current connectors and the mapping to the new connectors with pin shifts and additional connectors, I am sure that members would be more than happy to pay for a copy of this as it would make understanding the job so much easier and ensure that people are not asking the same questions over and over.
I want to consider this properly as I would need to cut the supporting bar for the old radio cassette unit which makes the process non-reversible.
Any help would be really appreciated before I abandon this altogether.
Cheers.
Guess that I will be giving up on this as no-one has been able to help. Ta to those who have responded to date.
Anyone else tempted to try on a car with a radio cassette system (i.e. no Comand) let me know. If anyone wants a Comand 2.0 let me know.
Cheers
If anyone know's how to expand tv picture from old tv-tuner to full screen of new retrofit Comand 2.0 please tell . When i disconnect the C2 connector with CAN-signal to the tv-tuner and reconect it with swiched on comand picture is expand to the full screen , but when i power off the comand and then on the picture of tv-tuner is back to 4:3 :crybaby2:
the price for the unit is $1233 but could use more info on the actual unit here is a translate from the page
Fits W220 S-Class. Do you like the MB original look, so is this unit for you.
- Suitable for a facelift panel.
- Fits 03-06 W220 & W215
- Also fits 99-02 if you do facelift conversion.
- Plug n Play. Everything works as with the original stereo.
- Everything will speed up in the info as before.
- Steering wheel buttons works as before.
- Original CD changer fits into it.
- Original Subwoffer suited to it!
- Ready to September-October 2010!!
1st 7.0 inch digital car dvd player (800 * 480) with a subwoofer output and you can link to the original subwoofer!
2nd Speed camera warning function or rear vision.
3rd CDC: Compatible for the original six CDC or CDC 10
4th DVB-T Can Be optional fee (30km/per hour, support wire antenna, impove signal sensitivity)
5th E-book function - E-book: read, browse and games pics
6th Steering Wheel Control (CAN BUS compatible air conditioning)
7th Bluetooth: BT-music, phone book, call
8th Mucic: MP3, MP4, IPOD ready
9th Optional TMC: Traffic Message Channel
10th Tire Pressure Monitoring System: compatible for those who have it.
11th SD card: Great NAV software or multimedia document.support New Type SDHC Card, Max 32GB
12th Victims USB HOST1.1 Jack, can read U disc, card reader
13th 17 languages to choose from:: English, Germantown, French, Spanish, Dutch, Hungarian, Czech, Danish, Norwegian, Swedish, Portuguese, Italian, Finland, Roumania, Greek, Russian, Poland
14th Radio Area: China, U.S., Latin America, Europe, Ressia Japan
15th Compatible with DVD, VCD, CD, MP3, MPEG4, CD-R, WMA and JPEG play-backs
16th Built-in AM / FM Radio, RDS, movie, Time, Calendar
17th Built-in amplifier 4x45watt
Navigation Software equest
1st WinCE.net 5.0 CORE
2nd Built-in GPS. 17 languages to choose from:
English,
Germantown,
French,
Spanish
Dutch,
Hungarian,
Czech,
Danish,
Norwegian,
Swedish,
Portuguese,
Italian,
Finnish;
Roumania,
Greek,
Russian,
Poland
3rd GPS Dual zone function
4th Navigation PCBs COM2, Baud Rate: 9600bps, The Path of storageing SD CARDS map: \ Storage Card \ *. exe, The Path of storageing NAND flash map: \ Nand Flash \ *. exe.
5th Maps to suit: Igo 8, Route66, Gate5, Papagos
Just wanted to share this great upgrade I did my self...Everything working.
So my next step I was thinking about is:
The W203 NTG1 comand with DVD has the exact same buttons on the front panel as the W220 but dont use MOST so I was thinking, would it not be possible to buy a W220 unit and a W203 unit and just swop the inside from the W203 unit to the W220 unit and there you have a DVD version in your old W220...??? What you think about that?
Hello Chris, I want to replace my old comand 2.5 on my S-Class W220 (year 1999) with new comand 2.0 widescreen. Which parts do I need? What about speed signal? Please let me know. Thanks
About this Discussion
32 Participants
Skylaw
Mercedes-Benz Forum
Full Forum Listing
