hello i have a problem with a w211 keeps the battery lamp on i have honored the small battery i have honored all the front and battery pack but it has not turned off yet where the problem may be
MY05 CLK55 AMG ,CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
If when you say honoured ,,you mean charged ,,,
Check voltage when engine is running ,,it should be 14.3 or 14.4 volts...
If it is lower ,then the problem could be the alternator...or the alternator voltage regulator,,,
2005 E320 CDI *black on black with nearly every option*
Charging system issue. Have the ECU's codes read to honored for any alternator/ battery control module faults.
