I don’t have an answer for you but I do have a question. What code if any and what symptoms told you that ecu is what you needed? I would be so greatful tip hear your thoughts on any of this. My car just had an check enmisson control sign come up, after car had been losing lack of power at take off & every so often not going into gear or loss of reverse these were just for a a few minutes but before I got it in shop it came out of ( Cruise Control) while driving home on highway then check engine light came on. I then read codes with Auto Zobes Code Reader giving me 4 codesHey guys,
would anybody happen to know the part number and any leads as to where I can find the Parktronic Ecu control module for my 2002 e430. The dealer wants an exorbitant amount of money for this largely unnecessary gizmo, and I want to be able to find perhaps a second hand one as i have found a few on ebay, but cannot tell for sure if they will work with my facelift w210.
Thanks in advance!
1 P01160
02 Heater circuit no activity detected bank 2 Sensor 2
2. P0161
02S 2Heater Circuit Malfunction
3P2768
Input Turbine Speed Sensor B circuit intermit
4 P2767 Same thing.
I understand this is not the MB diagnos
tool. I had my car towed to Euro Motors in Indianapolis,In.
they came back with telling me I needed a new transmission conductor plate? But unfortunately Mercedes Nenz had to repair that @around 2000$ to $ 2300 because it had to be programmed by them. After it was towed to ito MB I got a call 3 days later explaining previous place had wiped codes & engine light was off they had been driving it daily trying to see if any codes would come back and they had not. They then told me nothing they could do & it seemed to be running fine . A day later I was told i did not need a conductor plate but I had an oil leak at the crank case & it needed replaced & replace right valve gasket,my brake fluid was contaminated needs flush cleaned replaced. I needed a right rear ball joint ,new wipers, Costs $ 3000. plus I have 2 very different things totally different and have no idea what to do. Any help would be gladly appreciated. My MB is 2005 E 500 Series Sedan With the 211 Chasis
Thank you in advance.
mysedan
