1 - 8 of 8 Posts
2007 W211 E280
Hi
Would the following AMG sway bars fit my E280?
2007 W211 E280
May I ask the reason that you want to fit the AMG sway bar into your E280?
No real pressing reason. More for "wow" factor. I've read elsewhere that the rear sway bar takes a number of hours to replace, and that the front is easier.
I plan on doing some track days at a local track nearby in Sydney.
Take a look at the way the front sway bar is mounted to the front subframe. Is attached to the top of the subframe. I looked at it and the only way to remove the sway bar is to drop the subframe. Please somebody correct me if I'm wrong.
1 - 8 of 8 Posts
