1 - 10 of 10 Posts
2001 Mercedes Benz ML430 w163,2008 Mercedes Benz CLS550, RIP Mercedes Benz 1996 e320 w210
Since I have much more in common with you guys than with m112 engines I decided to post here:)
So I am having some stalling with my engine and I have decided its my cps sensor however when I was changing my auxiliary fans I tried looking for the location of CPS sensor and I couldn't see it. So please if anyone changed it before and/or has WIS instruction that would help me put that bad boy in. It's coming from states on August 9 do I have this time to locate it:)
Thanks in advance
Sent from my Autoguide iPhone app
The CPS is on top of the bellhousing by the oil filter housing.
Have you verified that your car is free from the dreaded eco junk wiring, including the ETA???
Check the harness build date tag and the code on the ETA. If either were made before 1998, you still have eco junk wiring. These cars are nearly impossible to troubleshoot electrically unitl the eco junk wiring has been replaced.
Thanks for information. I will give it another look. Can't drive anyways car is parked.
Sorry this might be a noob question but what ETA? An my car is 1996. 96 and 97 came with m104
'04 W211 E240, MY10 W204 C300
You need to look at your actual manufacture date.
Depending on the market, the problematic wiring for W210's was corrected in December 1996.
Even though your car might be a "97" model it may have been manufactured before the wiring issue was changed.
Ahh I see thank you guys for your inputs greatly appreciate it.
I will check the date of production and will get back to you guys after I put in the CPS sensor
Today the sensor is coming
So I decided to remove the old CPS
but I CAN'T see the damn thing.
Please help out.
Here is the pic
2001 C320 W203 Black on Black. 1997 E320 W210 Silver (RIP). 1995 E320 W124 Pearl Black.
On the M104 engine you can see the CPS from underneed the car. I don't need to replace mine yet, but curiosity after read too many post just look and find it from underneed. Just note I'm small oriental guy though, might be better if the car's on the lift/hoist if you're bigger than me.
Yea the wis says to remove starter but the top bolt is as hard to reach with tools, gotta get some special extensions.
Here is a diagram of CPS
1 - 10 of 10 Posts
