1 - 10 of 10 Posts
Today I got a low coolant level warning in my w210 that still has the m104 engine.
When I checked, the reservoir was empty, and I noticed what seemed like a gold sparkly powder lining some of the reservoir.
I was able to scrap some off with my finger, and it was literally like 14k gold sludge of some sort.
I am sure this is something bad. It runs fine, doesn't run hot, and only has 125k miles on it.
Any advice for me? I appreciate any help!
So this is a sign of cooling system sealant? I purchased the car about a year ago from a one-owner. Even had it checked out by Mercedes before purchasing. Think I was scammed?
The car sat for about 10 years before being sold. I have attached photos. The car isn't running warm at all and drove all through the summer just fine.
2607078
2607079
You had sufficient coolant in the system, and now you have a warning. If you do not find where the leakage is and fix it, you will have problems with overheating sooner or later.
Flush the system several times and do a pressure test with a radiator pressure teeter with the correct adapter.
Hopefully it is not a start of a head gasket issue. These engines are known to have this problem.
Will do. I am hoping it is not a head gasket issue or worse. If I do determine what the leak is, and fix it, should I also do a MB acid flush too? What would I do to reverse the sludge situation?
Well find and fix the leak first. If the radiator is leaking you need to replace the radiator anyway. If the engine is not overheating, I would not get into citric acid treatment. Just running with distilled water till nothing sludge comes out and then put 50/50 coolant + distilled water. Make sure that the heater is turned on fully when cleaning the system with distilled water.
Do you have oil leaks of any kind?
1 - 10 of 10 Posts
