1 - 15 of 15 Posts
i get warning messages break ,ABS and ETS and it don change gears i
i change the break light switch and i reapirt the K-40 relay
and still the same
anybody please help me
1998 E320 base sedan @ 160kmiles
Hello :).
What year ?
Any fault codes ?
Have you checked the wheel speed sensors ?
hello :)
1996
fault codes the same like the messages
no i dont checked
the messages often comes when i start the car
2000 E430
His car is a 1996 model. No 722.6 transmission.
The reading of the OBD1 will not get him anywhere. He needs to read the Traction module codes from the 38 pin connector.
2000 E430
Yes, you are correct. The video shows the location of the 38 pin connector, about 6 min in, and the proper scanner. He is obviously unfamiliar with both.
Discussion Starter #11
can the transmission make this problems ABS ,ETS ....
the transmission shift perfect but when i get this messages gets in limp mode
Discussion Starter #14
2610505
this 2 wires was connected with a diode the problem was not there
now the diode is burned and i become the problem
anyone know this
sorry i don't show this on the start
1 - 15 of 15 Posts
