Hello,
I'm from Malaysia. My ride is E270 CDI. Recently the W210 turbo behaves abnormal. The turbo sometime not able to turn on after I start the engine. I need to swich off the engine and restart in order to get it right. When is it okay and the engine still on it will continue to be fine until i switch off the engine.
Please advise and very your input is very aprepciated.
Thank you.
Those engines "never made it" to USA and that is where most of members are.
There is quite some discussion about turbos on 320 cdi in W211 section. You might want to check if that could be useful for you?
