1 - 10 of 10 Posts
Mercedes - Benz E300 TD Avantgarde
Please could anybody give an advice how to remove glove box to get to the cabin filters?
I unscrew the 6 screws but there are 2 another left near glove box lamp and I do not know how to unscrew them to remove glove box.
Is there any other filter for automatic air condition or just that one in glove box?
Thank you in advance.
I have taekn out all the screws, but the box seems to be fastened on the top center.
yes i took out the lamp and the screw that holds the latch and two on either side of the lamp. What am i missing?
2000 e 320 Matic
changing oil the wrong way
hi all,
I recently changed the oil on my first E320, a wonderful car then found out that the recommended method is to evacuate with a pump rather thne drain from oil pan. Now I have slow drip from the plug that I have tightened as much as I "feel" I can without worry that I might strip it. does any know the tourqe settings for this plug so I can tighten to specs and ensure that its the plug and not another soruce of a leak. I do all my own work so please do not respond with a dealers number. thank you
:confused:
1 - 10 of 10 Posts
