2002 W210 E55
AC doesn't blow cold.
Sensor readings - after 3 minutes (after 10 minutes)
1: 75 (80)
2: 75 (76)
3: 73 (89)
4: 73 (93)
5: 73 (76)
6: 163 (182)
7: 00 (01)
8: 71 (75)
DCT Codes
B1226 - In-car temperature sensor (B10/4)
B1416 - Coolant circulation pump (M13)
B1422 - Series interface (K1) connection to instrument cluster (A1)
I reset the codes and now I have no codes being thrown. I think B1416 is only heating related, so don't care about that for now.
The sensor 7 (compressor pressure) was at 0 and then finally came up to 1 after I filled with r134a until the gauge said full. Do I need more refrigerant? I'm afraid to fill past "full" into the "alert" area of the gauge, but the code seems to indicate the refrigerant is low (or is the compressor just not running?).
Any help appreciated, thanks
1: 75 (80)
2: 75 (76)
3: 73 (89)
4: 73 (93)
5: 73 (76)
6: 163 (182)
7: 00 (01)
8: 71 (75)
DCT Codes
